I wanted to run appimages on EOS, but the AppimagePool app, which is used to find and install appimages, crashes on startup. Has anyone experienced anything like this?
I am not using AppimagePool but perhaps if you could launch it from a terminal and post any error messages you get, someone in the forum might be able to make sense of it.
Otherwise, I think you could use bauh
(AUR) as well to search for and downlowd appimages.
I don’t use that either
I think the app I used to use was appimage launcher
or similar. It worked great for a long time, but I don’t need it anymore. You may want to check it out.
Interestingly, it runs in a terminal, although there is an error message.
./appimagepool-x86_64.AppImage
flutter: Unsupported operation: Unsupported clipPath child g
flutter: #0 debugPrintStack (package:flutter/src/foundation/assertions.dart:1196)Interestingly, it runs in a terminal, although there is an error message.
flutter: #1 FlutterError.dumpErrorToConsole (package:flutter/src/foundation/assertions.dart:1017)
flutter: #2 FlutterError.reportError (package:flutter/src/foundation/assertions.dart:1177)
flutter: #3 _Elements.clipPath (package:flutter_svg/src/svg/parser_state.dart:535)
flutter: #4 SvgParserState.parse (package:flutter_svg/src/svg/parser_state.dart:948)
flutter: <asynchronous suspension>
flutter: #5 SvgParser.parse (package:flutter_svg/parser.dart:27)
flutter: #6 Svg.fromSvgString (package:flutter_svg/svg.dart:137)Interestingly, it runs in a terminal, although there is an error message.
flutter: #7 Svg.svgPictureDecoder (package:flutter_svg/svg.dart:57)
flutter: Another exception was thrown: Instance of 'DiagnosticsProperty<void>'
nouveau: kernel rejected pushbuf: Nincs il./appimagepool-x86_64.AppImage
flutter: #1 FlutterError.dumpErrorToConsole (package:flutter/src/foundation/asseInterestingly, it runs in a terminal, although there is an error message.rtions.dart:1017)
flutter: Another exception was thrown: Instance of 'DiagnosticsProperty<void>'Interestingly, it runs in a terminal, although there is an error message.
nouveau: kernel rejected pushbuf: Nincs ilyen fájl vagy könyvtár
nouveau: ch6: krec 0 pushes 2 bufs 22 relocs 0
nouveau: ch6: buf 00000000 00000003 00000004 00000004 00000000 0x7f95243c5000 0x95000 0x80000
nouveau: ch6: buf 00000000 00000004 00000004 00000004 00000000 0x7f9514100000 0x115000 0x80000
Another question that arises is: How can a shortcut be opened in a terminal from a context menu on a Cinnamon desktop? It is set in Nemo settings but does not appear in the context menu.
Thanks, I’m going to look at this, but to the best of my knowledge, the appimage launcher integrates those appimage files into the system as an executable, doesn’t it?
I believe it gives you the option when you install each package.
The appimagelauncher works, I can start the stacer with it once, but also integrated. However, there is something wrong with appimagepool because I get an error message when starting from a terminal. This app is running flawlessly on my test laptop on EOS. The difference is that my desktop has an nvidia video card with a nouveau driver, while my laptop has an Intel integrated video card.
The error message:
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 472, resource id: 12612350, major code: 40 (TranslateCoords), minor code: 0
nouveau: ch5: krec 0 pushes 2 bufs 24 relocs 0
nouveau: ch5: buf 00000000 00000003 00000004 00000004 00000000 0x7fdd9c6ed000 0x95000 0x80000
nouveau: ch5: buf 00000001 00000006 00000004 00000000 00000004 0x7fddb1aad000 0x215000 0x1000
nouveau: ch5: krec 0 pushes 0 bufs 1 relocs 0
nouveau: ch5: buf 00000000 00000004 00000004 00000004 00000000 0x7fdd8c800000 0x115000 0x80000
nouveau: ch5: krec 0 pushes 2 bufs 53 relocs 0
nouveau: ch5: buf 00000000 00000005 00000004 00000004 00000000 0x7fdd8c8e0000 0x195000 0x80000
nouveau: ch5: buf 00000002 00000061 00000004 00000004 00000000 0x7fddb0000000 0xf38000 0x1000
nouveau: ch5: buf 00000003 0000002e 00000002 00000002 00000002 (nil) 0x2580000 0x400000
nouveau: ch5: buf 00000004 00000014 00000002 00000002 00000000 (nil) 0x1460000 0x400000
nouveau: ch5: buf 00000005 00000008 00000002 00000002 00000002 (nil) 0x2c0000 0xe0000
nouveau: ch5: buf 00000006 0000000b 00000002 00000002 00000002 (nil) 0x7c0000 0x20000
nouveau: ch5: buf 00000007 0000000a 00000002 00000002 00000002 (nil) 0x6c0000 0x100000
nouveau: ch5: buf 00000008 0000004c 00000002 00000002 00000002 (nil) 0x3020000 0x100000
nouveau: ch5: buf 00000009 00000007 00000002 00000002 00000000 (nil) 0x240000 0x80000
nouveau: ch5: buf 0000000a 0000003a 00000002 00000002 00000000 (nil) 0x44c0000 0x3a0000
nouveau: ch5: buf 0000000b 0000001d 00000004 00000004 00000000 0x7fdd9c76d000 0x1c20000 0x20000
nouveau: ch5: buf 0000000c 0000004e 00000002 00000002 00000002 (nil) 0xf6f000 0x4000
nouveau: ch5: buf 0000000d 00000037 00000002 00000002 00000000 (nil) 0x3280000 0x160000
nouveau: ch5: buf 0000000e 0000003c 00000002 00000002 00000002 (nil) 0xefa000 0x4000
nouveau: ch5: buf 0000000f 00000040 00000002 00000002 00000000 (nil) 0x5040000 0x560000
nouveau: ch5: buf 00000010 0000003b 00000002 00000002 00000002 (nil) 0xf20000 0x4000
nouveau: ch5: buf 00000011 0000002f 00000002 00000002 00000000 (nil) 0x2d28000 0x16000
nouveau: ch5: buf 00000012 0000003f 00000002 00000002 00000002 (nil) 0xefe000 0x4000
nouveau: ch5: buf 00000013 0000003e 00000002 00000002 00000000 (nil) 0xf02000 0x6000
nouveau: ch5: buf 00000014 00000010 00000002 00000002 00000002 (nil) 0xf80000 0x3c0000
nouveau: ch5: krec 0 pushes 1 bufs 12 relocs 0
nouveau: ch5: buf 00000002 00000067 00000002 00000000 00000002 (nil) 0x4c80000 0x60000
nouveau: ch5: buf 00000003 00000068 00000004 00000004 00000000 0x7fdd8c8a0000 0x4ce0000 0x40000
nouveau: ch5: buf 00000002 00000075 00000002 00000000 00000002 (nil) 0x4ae0000 0x60000
nouveau: ch5: buf 00000003 00000076 00000004 00000004 00000000 0x7fdd8c8a0000 0x4b40000 0x40000
nouveau: ch5: buf 00000004 0000007c 00000004 00000004 00000000 0x7fdd8cd8c000 0x4acc000 0x10000
nouveau: ch5: buf 00000005 0000007d 00000004 00000004 00000000 0x7fdda8000000 0x4adc000 0x4000
nouveau: ch5: buf 00000006 0000007e 00000004 00000004 00000000 0x7fddb0054000 0xf73000 0x1000
nouveau: ch5: buf 00000007 0000007f 00000004 00000004 00000000 0x7fdda8100000 0x3414000 0x1000
nouveau: ch5: buf 00000008 00000080 00000004 00000004 00000000 0x7fdd9c6ec000 0x341e000 0x1000
nouveau: ch5: buf 00000009 00000081 00000004 00000004 00000000 0x7fdd9c6eb000 0x341f000 0x1000
nouveau: ch5: buf 0000000a 00000082 00000004 00000004 00000000 0x7fdd9c6ea000 0x4c7e000 0x1000
nouveau: ch5: buf 0000000b 00000083 00000004 00000004 00000000 0x7fdd9c6e9000 0x4c7f000 0x1000
nouveau: ch5: psh 00000000 00000732d0 0000073818
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000040
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000100
nouveau: 0x00000100
nouveau: 0x00000000
nouveau: 0x04ae0000
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000400
nouveau: 0x00000100
nouveau: 0x00000100
nouveau: 0x00000000
nouveau: 0x04b40000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000100
nouveau: 0x00000100
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000040
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000080
nouveau: 0x00000080
nouveau: 0x00000000
nouveau: 0x04b20000
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000200
nouveau: 0x00000080
nouveau: 0x00000080
nouveau: 0x00000000
nouveau: 0x04acc000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000080
nouveau: 0x00000080
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000030
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000040
nouveau: 0x00000040
nouveau: 0x00000000
nouveau: 0x04b30000
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000100
nouveau: 0x00000040
nouveau: 0x00000040
nouveau: 0x00000000
nouveau: 0x04adc000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000040
nouveau: 0x00000040
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000020
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000020
nouveau: 0x00000020
nouveau: 0x00000000
nouveau: 0x04b34000
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000080
nouveau: 0x00000020
nouveau: 0x00000020
nouveau: 0x00000000
nouveau: 0x00f73000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000020
nouveau: 0x00000020
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000010
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000010
nouveau: 0x00000010
nouveau: 0x00000000
nouveau: 0x04b35000
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000080
nouveau: 0x00000010
nouveau: 0x00000010
nouveau: 0x00000000
nouveau: 0x03414000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000010
nouveau: 0x00000010
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000008
nouveau: 0x00000008
nouveau: 0x00000000
nouveau: 0x04b35400
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000080
nouveau: 0x00000008
nouveau: 0x00000008
nouveau: 0x00000000
nouveau: 0x0341e000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000008
nouveau: 0x00000008
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000004
nouveau: 0x00000004
nouveau: 0x00000000
nouveau: 0x04b35600
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000080
nouveau: 0x00000004
nouveau: 0x00000004
nouveau: 0x00000000
nouveau: 0x0341f000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000004
nouveau: 0x00000004
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000002
nouveau: 0x00000002
nouveau: 0x00000000
nouveau: 0x04b35800
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000080
nouveau: 0x00000002
nouveau: 0x00000002
nouveau: 0x00000000
nouveau: 0x04c7e000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000002
nouveau: 0x00000002
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x20056080
nouveau: 0x000000d5
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x20046086
nouveau: 0x00000001
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x04b35a00
nouveau: 0x800060ae
nouveau: 0x2002608c
nouveau: 0x000000cf
nouveau: 0x00000001
nouveau: 0x20056091
nouveau: 0x00000080
nouveau: 0x00000001
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x04c7f000
nouveau: 0x80006223
nouveau: 0x2004622c
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000001
nouveau: 0x20046230
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x00000000
nouveau: 0x00000001
nouveau: 0x20046234
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x00000000
nouveau: 0x200406c0
nouveau: 0x00000000
nouveau: 0x00215000
nouveau: 0x000000ee
nouveau: 0x1000f010
nouveau: ch5: buf 00000000 00000002 00000004 00000004 00000000 0x7fddb09f9000 0x15000 0x80000
nouveau: ch5: buf 00000002 0000007c 00000004 00000004 00000000 0x7fddb0001000 0x7e4000 0x1000
nouveau: ch5: buf 00000004 0000002f 00000002 00000002 00000000 (nil) 0x2d28000 0x16000
nouveau: ch5: buf 00000008 00000069 00000002 00000002 00000002 (nil) 0x4c62000 0x1c000
nouveau: ch5: buf 0000000a 00000061 00000002 00000002 00000000 (nil) 0x39a0000 0x360000
nouveau: ch5: buf 0000000c 0000006a 00000002 00000002 00000002 (nil) 0x44bc000 0x3000
nouveau: ch5: buf 0000000d 00000012 00000002 00000002 00000000 (nil) 0x1360000 0x80000
nouveau: ch5: buf 0000000e 00000010 00000002 00000002 00000002 (nil) 0xf80000 0x3c0000
nouveau: ch5: krec 0 pushes 2 bufs 50 relocs 0
nouveau: ch5: buf 00000002 0000008d 00000004 00000004 00000000 0x7fddb0054000 0x44b5000 0x1000
nouveau: ch5: buf 00000005 0000001d 00000004 00000004 00000000 0x7fdd9c76d000 0x1c20000 0x20000
nouveau: ch5: buf 00000006 00000008 00000002 00000002 00000002 (nil) 0x2c0000 0xe0000
nouveau: ch5: buf 00000007 0000000b 00000002 00000002 00000002 (nil) 0x7c0000 0x20000
nouveau: ch5: buf 00000008 0000000a 00000002 00000002 00000002 (nil) 0x6c0000 0x100000
nouveau: ch5: buf 00000009 0000006f 00000002 00000002 00000002 (nil) 0x2c7c000 0x3000
nouveau: ch5: buf 0000000a 00000012 00000002 00000002 00000000 (nil) 0x1360000 0x80000
nouveau: ch5: buf 0000000b 00000007 00000002 00000002 00000000 (nil) 0x240000 0x80000
nouveau: ch5: buf 0000000c 00000010 00000002 00000002 00000002 (nil) 0xf80000 0x3c0000
nouveau: ch5: krec 0 pushes 2 bufs 51 relocs 0
nouveau: ch5: buf 00000002 0000008f 00000004 00000004 00000000 0x7fddb0001000 0x7e9000 0x1000
