Anyone using Solokey or Yubikey in EnOS?
As per Arch wiki, It seems that Yubikey is not fully compatible with Linux
Edit: Correction, arch wiki just saying that yubikey is not opensource, nothing about compatibility
I’m thinking about buying one, but I just started my research, if someone has experience with it in Linux, kindly share your thoughts and experience, thanks.
I used yubikey on linux, you just plug it into usb and touch with finger to activate for example via lastpass for two factor autentification. It worked
But that was on ubuntu about 1-2 years ago. I can grab it and try in eos if it gives you piece of mind? Its pretty nice and easy to set up.
Edit: I think you need to try your own because they released new versions since I tried them
