Anyone using lkrg?
A search forum wide yielded nothing. Curious if anyone is using lkrg?
I installed it earlier today after updating to 5.11.15 and running NVidia 465.24.02 without problems.
More here
https://www.openwall.com/lkrg/
and possible performance effects here
https://www.phoronix.com/scan.php?page=article&item=lkrg-08-linux&num=1
regards
Mana?
Hi LizzieAS
Dont know if its like mana (Kali) for RAP protection per se.Interesting concept… I decided to use it given NVidia drivers on my gfx solution of choice. Not that I dont trust the drivers, but everything in between.
Forgot to add-- the machine with Endeavour is a desktop, not wifi capable so at least part of RAP vulns as they may be commonly perceived…are not present.
Other than the drivers I mentioned, the only other thing --other than normal attack surfaces presented by a machine running on an Eth LAN where I control not only the gateway but everything else on the LAN–is a piece of native Linux ware I use to look at various cryptos. Other than that there isnt much other than, again, normal attack surfaces…
