Yes - that is what the table on the wiki page says, so it’s to be expected. “0” is no access, “2” is write access. It’s doing what you’re telling it to do.
Strongly recommend this primer on permissions :
Two things:
- It is a mask, so doesn’t it have the opposite meaning? In this case, create files without write access for “other”?
- He is testing with the group permissions and that is the byte for “other”
It doesn’t look like it does based on the permissions you showed above. However, I am not sure umask is what you want in this case. To be honest I didn’t even know that a cifs mount supported umask
I think you want to set file_mode
and dir_mode
Try replacing the umask with this:
file_mode=0664,dir_mode=0775
Heh, look at me getting confused with the Arch wiki. Good job I raised that here!
Solved for now.
