Hi,
My disks list display in Gparted no longer works. Will I be the only one with this problem?
Can you better explain what you mean? There isn’t much we can do with “No longer works”.
Are you getting an error? Something else?
At the top right I can see my nvme SSD displayed there. When I click on the arrow, the scrolling list opens quickly and disappears immediately. No error.
- Have you rebooted since your last time installing updates?
- Is your system fully-updated?(Yes, this really matters. A partially updated system can cause applications to not function properly)
- Have you tried running the application from a terminal to see if any errors show up in the terminal window.
Could you try dragging instead of simply clicking? Meaning click on drop-down, don’t lift the mouse button. Drag cursor to other disk you want to select then lift button.
Sometimes I have problems with eight click menu in Firefox and this is what I do to get around it.
I did restart EOS after the update.
I have the same problem when I run from the terminal.
Do any messages show up in the terminal when the problem occurs?
No that doesn’t work for me anymore. I am unable to keep the display of this list.
No message.
Can you click on the gparted menu, go to devices and select your disk that way? Also, do you have more than one disk?
Yes! it works that way.
I have 4 devices.
[armand@Desktop-living ~]$ sudo fdisk -l
[sudo] Mot de passe de root :
Disque /dev/nvme0n1 : 476,94 GiB, 512110190592 octets, 1000215216 secteurs
Modèle de disque : ADATA SX8200PNP
Unités : secteur de 1 × 512 = 512 octets
Taille de secteur (logique / physique) : 512 octets / 512 octets
taille d’E/S (minimale / optimale) : 512 octets / 512 octets
Type d’étiquette de disque : gpt
Identifiant de disque : 4F26E749-A82E-AF40-A0E3-E8B95F7EA13B
Périphérique Début Fin Secteurs Taille Type
/dev/nvme0n1p1 4096 618495 614400 300M Système EFI
/dev/nvme0n1p2 618496 215701503 215083008 102,6G Système de fichiers Linux
/dev/nvme0n1p3 964119146 1000206899 36087754 17,2G Partition d’échange Linux
/dev/nvme0n1p4 482457797 964119145 481661349 229,7G Système de fichiers Linux
/dev/nvme0n1p5 215701504 482457599 266756096 127,2G Système de fichiers Linux
Les entrées de la table de partitions ne sont pas dans l’ordre du disque.
Disque /dev/sda : 465,76 GiB, 500107862016 octets, 976773168 secteurs
Modèle de disque : CT500MX500SSD1
Identifiant de disque : 041A544F-78DD-4E39-9A77-8CDF346A49F7
/dev/sda1 2048 409602047 409600000 195,3G Données de base Microsoft
/dev/sda2 409602048 513841151 104239104 49,7G Système de fichiers Linux
/dev/sda3 513841152 630661119 116819968 55,7G Système de fichiers Linux
Disque /dev/sdb : 931,51 GiB, 1000204885504 octets, 1953525167 secteurs
Modèle de disque : Expansion
Type d’étiquette de disque : dos
Identifiant de disque : 0x22dabe6a
Périphérique Amorçage Début Fin Secteurs Taille Id Type
/dev/sdb1 2048 1048417964 1048415917 499,9G 7 HPFS/NTFS/exFAT
Disque /dev/sdc : 931,48 GiB, 1000170586112 octets, 1953458176 secteurs
Modèle de disque : Elements 25A2
Identifiant de disque : EA9F8B36-70DE-40B0-A7AE-79489B15618A
/dev/sdc1 2048 1953456127 1953454080 931,5G Données de base Microsoft
Thank you dalto for your help.
I just saw that when I use the up and down arrows it works, it offers me all the disks.
The problem is with the use of the mouse. Well i will live like this…
If you click on an item, then right click and go to “properties” it will show you a list of which applications that can open that item. You can then choose which application with which to open it. More importantly you can change applications by using the up/down arrows to change priority. Sorry if I am stating the obvious but this applies to most DEs as far as I know.
