journalctl -b0 -g api
-- Journal begins at Sun 2020-12-06 07:56:30 CET, ends at Sat 2021-01-09 09:22:34 CET. --
Jan 09 09:14:46 rakete kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-manjaro-xanmod root=UUID=0a765f87-6eca-4e05-bd1a-36ac4ba3fb8f rw audit=0 nmi_watchdog=0 apic=debug quiet loglevel=3
Jan 09 09:14:46 rakete kernel: ACPI: APIC 0x00000000CB2DA000 00015E (v03 ALASKA A M I 01072009 AMI 00010013)
Jan 09 09:14:46 rakete kernel: ACPI: Local APIC address 0xfee00000
Jan 09 09:14:46 rakete kernel: mapped APIC to ffffffffff5fd000 ( fee00000)
Jan 09 09:14:46 rakete kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: apic_id 17, version 33, address 0xfec00000, GSI 0-23
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: apic_id 18, version 33, address 0xfec01000, GSI 24-55
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 00, APIC ID 11, APIC INT 02
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 3, trig 3, bus 00, IRQ 09, APIC ID 11, APIC INT 09
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 01, APIC ID 11, APIC INT 01
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 03, APIC ID 11, APIC INT 03
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 04, APIC ID 11, APIC INT 04
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 05, APIC ID 11, APIC INT 05
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 06, APIC ID 11, APIC INT 06
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 07, APIC ID 11, APIC INT 07
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 08, APIC ID 11, APIC INT 08
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 0a, APIC ID 11, APIC INT 0a
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 0b, APIC ID 11, APIC INT 0b
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 0c, APIC ID 11, APIC INT 0c
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 0d, APIC ID 11, APIC INT 0d
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 0e, APIC ID 11, APIC INT 0e
Jan 09 09:14:46 rakete kernel: Int: type 0, pol 0, trig 0, bus 00, IRQ 0f, APIC ID 11, APIC INT 0f
Jan 09 09:14:46 rakete kernel: mapped IOAPIC to ffffffffff5fc000 (fec00000)
Jan 09 09:14:46 rakete kernel: mapped IOAPIC to ffffffffff5fb000 (fec01000)
Jan 09 09:14:46 rakete kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-manjaro-xanmod root=UUID=0a765f87-6eca-4e05-bd1a-36ac4ba3fb8f rw audit=0 nmi_watchdog=0 apic=debug quiet loglevel=3
Jan 09 09:14:46 rakete kernel: APIC: Switch to symmetric I/O mode setup
Jan 09 09:14:46 rakete kernel: Switched APIC routing to physical flat.
Jan 09 09:14:46 rakete kernel: ENABLING IO-APIC IRQs
Jan 09 09:14:46 rakete kernel: init IO_APIC IRQs
Jan 09 09:14:46 rakete kernel: apic 17 pin 0 not connected
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-1 -> 0xef -> IRQ 1 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-2 -> 0x30 -> IRQ 0 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-3 -> 0xef -> IRQ 3 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-4 -> 0xef -> IRQ 4 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-5 -> 0xef -> IRQ 5 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-6 -> 0xef -> IRQ 6 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-7 -> 0xef -> IRQ 7 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-8 -> 0xef -> IRQ 8 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-9 -> 0xef -> IRQ 9 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-10 -> 0xef -> IRQ 10 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-11 -> 0xef -> IRQ 11 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-12 -> 0xef -> IRQ 12 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-13 -> 0xef -> IRQ 13 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-14 -> 0xef -> IRQ 14 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[0]: Set routing entry (17-15 -> 0xef -> IRQ 15 Mode:0 Active:0 Dest:0)
Jan 09 09:14:46 rakete kernel: apic 17 pin 16 not connected
Jan 09 09:14:46 rakete kernel: apic 17 pin 17 not connected
Jan 09 09:14:46 rakete kernel: apic 17 pin 18 not connected
Jan 09 09:14:46 rakete kernel: apic 17 pin 19 not connected
Jan 09 09:14:46 rakete kernel: apic 17 pin 20 not connected
Jan 09 09:14:46 rakete kernel: apic 17 pin 21 not connected
Jan 09 09:14:46 rakete kernel: apic 17 pin 22 not connected
Jan 09 09:14:46 rakete kernel: apic 17 pin 23 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 0 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 1 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 2 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 3 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 4 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 5 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 6 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 7 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 8 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 9 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 10 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 11 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 12 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 13 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 14 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 15 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 16 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 17 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 18 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 19 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 20 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 21 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 22 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 23 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 24 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 25 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 26 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 27 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 28 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 29 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 30 not connected
Jan 09 09:14:46 rakete kernel: apic 18 pin 31 not connected
Jan 09 09:14:46 rakete kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Jan 09 09:14:46 rakete kernel: Using local APIC timer interrupts.
calibrating APIC timer ...
Jan 09 09:14:46 rakete kernel: ... lapic delta = 625003
Jan 09 09:14:46 rakete kernel: ACPI: Using IOAPIC for interrupt routing
Jan 09 09:14:46 rakete kernel: pps_core: LinuxPPS API ver. 1 registered
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-4 -> 0xef -> IRQ 24 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-6 -> 0xef -> IRQ 25 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-11 -> 0xef -> IRQ 25 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-15 -> 0xef -> IRQ 26 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: PPR X2APIC NX GT IA GA PC GA_vAPIC
Jan 09 09:14:46 rakete kernel: AMD-Vi: Virtual APIC enabled
Jan 09 09:14:46 rakete kernel: AMD-Vi: X2APIC enabled
Jan 09 09:14:46 rakete kernel: fuse: init (API version 7.32)
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-10 -> 0xef -> IRQ 30 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-5 -> 0xef -> IRQ 38 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-6 -> 0xef -> IRQ 40 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-30 -> 0xef -> IRQ 42 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: ... APIC ID: 00000000 (0)
Jan 09 09:14:46 rakete kernel: ... APIC VERSION: 80050010
Jan 09 09:14:46 rakete kernel: number of IO-APIC #17 registers: 24.
Jan 09 09:14:46 rakete kernel: number of IO-APIC #18 registers: 32.
Jan 09 09:14:46 rakete kernel: testing the IO APIC.......................
Jan 09 09:14:46 rakete kernel: IO APIC #17......
Jan 09 09:14:46 rakete kernel: ....... : physical APIC id: 11
Jan 09 09:14:46 rakete kernel: ....... : IO APIC version: 21
Jan 09 09:14:46 rakete kernel: IOAPIC 0:
Jan 09 09:14:46 rakete kernel: IO APIC #18......
Jan 09 09:14:46 rakete kernel: ....... : physical APIC id: 12
Jan 09 09:14:46 rakete kernel: IOAPIC 1:
Jan 09 09:14:46 rakete dracut-cmdline[318]: Using kernel command line parameters: audit=0 nmi_watchdog=0 quiet loglevel=3 rd.luks=0 rd.lvm=0 rd.md=0 rd.dm=0 BOOT_IMAGE=/boot/vmlinuz-manjaro-xanmod root=UUID=0a765f87-6eca-4e05-bd1a-36ac4ba3fb8f rw audit=0 nmi_watchdog=0 apic=debug quiet loglevel=3
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-0 -> 0xef -> IRQ 46 Mode:1 Active:1 Dest:0)
Jan 09 09:14:46 rakete kernel: IOAPIC[1]: Set routing entry (18-15 -> 0xef -> IRQ 76 Mode:1 Active:1 Dest:0)
Jan 09 09:14:47 rakete kernel: ata1.00: ATAPI: HL-DT-ST BD-RE BH16NS40, 1.03, max UDMA/100
Jan 09 09:14:54 rakete kernel: RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
Jan 09 09:14:54 rakete kernel: IOAPIC[1]: Set routing entry (18-31 -> 0xef -> IRQ 166 Mode:1 Active:1 Dest:0)
Jan 09 09:14:54 rakete kernel: IOAPIC[1]: Set routing entry (18-12 -> 0xef -> IRQ 168 Mode:1 Active:1 Dest:0)
