I use Timeshift and did restore a previous snapshot from choosing it in the Grub menu and then restoring it from the Timleshift program menu.
My question is did I did it right, as now if I try to update using pacman -Syu
i get /var/lib/pacman/db.lck
error message, I get Timeshift launching itself automatically on startup, and if I run
$ findmnt -nt btrfs
/ /dev/mapper/luks-58b599e1-b00f-4a1a-8a1c-b2f2366ecbcf[/timeshift-btrfs/snapshots/2021-10-22_02-13-34/@]
β btrfs rw,noat
ββ/run/timeshift/backup
β /dev/mapper/luks-58b599e1-b00f-4a1a-8a1c-b2f2366ecbcf btrfs rw,rela
ββ/swap
β /dev/mapper/luks-58b599e1-b00f-4a1a-8a1c-b2f2366ecbcf[/@swap] btrfs rw,rela
ββ/var/log
β /dev/mapper/luks-58b599e1-b00f-4a1a-8a1c-b2f2366ecbcf[/@log] btrfs rw,noat
ββ/home
β /dev/mapper/luks-58b599e1-b00f-4a1a-8a1c-b2f2366ecbcf[/@home] btrfs rw,noat
ββ/var/cache
/dev/mapper/luks-58b599e1-b00f-4a1a-8a1c-b2f2366ecbcf[/@cache] btrfs rw,noat
ββ/var/cache/pacman/pkg
/dev/mapper/luks-58b599e1-b00f-4a1a-8a1c-b2f2366ecbcf[/@var-cache-pacman-pkg] btrfs rw,noat
Did I βrestoreβ my system right ?
Cheers !
