Guys,
Fully updated eos Plasma install - akm (kernel manager) is not completing the “execute” option. The application opens and allows selection of kernels just fine.
Thanks,
GM
Guys,
Thanks,
GM
Thanks for the report!
I’ll debug akm.
Cheers manuel!
Found the reason (on a non-EOS app) and worked around it.
The remedy is in package eos-bash-shared
version 1.5.10-1.
So please update the system and try again. Hope it works now.
Hi @manuel !
A consultation, (I have plasma on my pc-desktop) since I can’t install the Hardened kernel by console, nor by Akm, I really don’t understand what I missed.
On my laptop I have installed it with Xfce without any problem to hardened …
To make it clearer what is happening to me with hardened:
I can install it without any problem from akm or console, but it doesn’t start in the session screen.
Can you show the output of:
pacman -Qs linux-hardened pacman -Qs grub-too
If I understand correctly what you are implying, maybe the grub menu is not updated?
Thank you for your prompt response @manuel !
Of course I can:
[soloyo@siempresolo ~]$ pacman -Qs linux-hardened
[soloyo@siempresolo ~]$ pacman -Qs grub-too
local/grub-tools 1.5-3
Fixes, additions and enhancements to grub and os-prober.
I happened to uninstall it, reinstall it and then pass those commands again ?
Please show the output of the following command:
sudo pacman -S linux-hardened linux-hardened-headers
I just installed it
$ LANG=C sudo pacman -S linux-hardened linux-hardened-headers
warning: linux-hardened-5.10.4.a-1 is up to date -- reinstalling
warning: linux-hardened-headers-5.10.4.a-1 is up to date -- reinstalling
resolving dependencies...
Packages (2) linux-hardened-5.10.4.a-1 linux-hardened-headers-5.10.4.a-1
Total Installed Size: 195,81 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n]
Installed with AKM:
pacman -S linux-hardened linux-hardened-headers ;
[sudo] password for soloyo:
resolviendo dependencias...
buscando conflictos entre paquetes...
Paquetes (2) linux-hardened-5.10.4.a-1 linux-hardened-headers-5.10.4.a-1
Tamaño total de la descarga: 91,39 MiB
Tamaño total de la instalación: 195,81 MiB
:: ¿Continuar con la instalación? [S/n]
:: Obteniendo los paquetes...
linux-hardened-5.... 69,1 MiB 1630 KiB/s 00:43 [---------------------------] 100%
linux-hardened-he... 22,3 MiB 1589 KiB/s 00:14 [---------------------------] 100%
(2/2) comprobando las claves del depósito [---------------------------] 100%
(2/2) verificando la integridad de los paquetes [---------------------------] 100%
(2/2) cargando los archivos de los paquetes [---------------------------] 100%
(2/2) comprobando conflictos entre archivos [---------------------------] 100%
:: Procesando los cambios de los paquetes...
(1/2) instalando linux-hardened [---------------------------] 100%
Dependencias opcionales para linux-hardened
crda: to set the correct wireless channels of your country
linux-firmware: firmware images needed for some devices [instalado]
usbctl: deny_new_usb control
(2/2) instalando linux-hardened-headers [---------------------------] 100%
:: Ejecutando los «hooks» de posinstalación...
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Install DKMS modules
(4/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-hardened.preset: 'default'
-> -k /boot/vmlinuz-linux-hardened -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-hardened.img
==> Starting build: 5.10.4.a-1-hardened
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [filesystems]
-> Running build hook: [fsck]
==> Generating module dependencies
==> Creating xz-compressed initcpio image: /boot/initramfs-linux-hardened.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-hardened.preset: 'fallback'
-> -k /boot/vmlinuz-linux-hardened -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-hardened-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating xz-compressed initcpio image: /boot/initramfs-linux-hardened-fallback.img
(5/5) Update grub after installing or removing a kernel or microcode.
Generating grub configuration file ...
Found theme: /boot/grub/themes/EndeavourOS/theme.txt
Found linux image: /boot/vmlinuz-linux-hardened
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-hardened.img
Found fallback initrd image(s) in /boot: initramfs-linux-hardened-fallback.img
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: initramfs-linux-fallback.img
Found Windows Boot Manager on /dev/sda1@/efi/Microsoft/Boot/bootmgfw.efi
done
Pulse ENTER para cerrar esta ventana:
I’d like to see if grub-tools are doing their job of updating the grub menu, so the full output is needed…
Assuming you are using grub?
If I’m using Grub.
So… can you clarify about “not starting” and “session screen”?
I restart and make captures so that I can see better since I can’t explain myself well.
→It stays there and does not advance to the login screen.
https://lkml.org/lkml/2020/11/30/1556
$ pacman -Qs grub-tools
Of course, I can’t get to type my password in SDDM to get to my desktop.
Looks like a kernel problem.
I try this here.
journalctl -p 3 -xb
– Journal begins at Wed 2020-12-02 19:40:29 -03, ends at Wed 2021-01-06 12:36:48 -03. –
ene 06 12:33:20 siempresolo kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20200925/psargs-330)
ene 06 12:33:20 siempresolo kernel: ACPI Error: Aborting method _SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
ene 06 12:33:20 siempresolo kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20200925/psargs-330)
ene 06 12:33:20 siempresolo kernel: ACPI Error: Aborting method _SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
ene 06 12:33:27 siempresolo kernel:
ene 06 12:33:27 siempresolo nmbd[459]: [2021/01/06 12:33:27.931238, 0] …/…/lib/util/become_daemon.c:147(daemon_status)
ene 06 12:33:27 siempresolo nmbd[459]: daemon_status: daemon ‘nmbd’ : No local IPv4 non-loopback interfaces available, waiting for interface …
ene 06 12:33:27 siempresolo nmbd[459]: [2021/01/06 12:33:27.937023, 0] …/…/source3/nmbd/nmbd_subnetdb.c:253(create_subnets)
ene 06 12:33:27 siempresolo nmbd[459]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
ene 06 12:33:27 siempresolo kernel: usbhid 1-7:1.1: couldn’t find an input interrupt endpoint
ene 06 12:33:29 siempresolo kernel: sd 6:0:0:0: [sdc] No Caching mode page found
ene 06 12:33:29 siempresolo kernel: sd 6:0:0:0: [sdc] Assuming drive cache: write through
ene 06 12:33:43 siempresolo systemd-coredump[952]: Process 749 (baloo_file) of user 1000 dumped core.
Stack trace of thread 950:
#0 0x00007fd04f562396 n/a (liblmdb.so + 0x4396)
#1 0x00007fd04f564efe n/a (liblmdb.so + 0x6efe)
#2 0x00007fd04f565644 n/a (liblmdb.so + 0x7644)
#3 0x00007fd04f565c50 mdb_get (liblmdb.so + 0x7c50)
#4 0x00007fd050a3c2a5 _ZN5Baloo12IdFilenameDB3getEy (libKF5BalooEngine.so.5 + 0x152a5)
#5 0x00007fd050a362fc _ZNK5Baloo13DocumentUrlDB3getEy (libKF5BalooEngine.so.5 + 0xf2fc)
#6 0x00007fd050a47085 _ZNK5Baloo11Transaction11documentUrlEy (libKF5BalooEngine.so.5 + 0x20085)
#7 0x000055657d4e38e4 n/a (baloo_file + 0x1d8e4)
#8 0x00007fd050a4e4ff _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x274ff)
#9 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#10 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#11 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#12 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#13 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#14 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#15 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#16 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#17 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#18 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#19 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#20 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#21 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#22 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#23 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#24 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#25 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#26 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#27 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#28 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#29 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#30 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#31 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#32 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#33 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#34 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#35 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#36 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#37 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#38 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#39 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#40 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#41 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#42 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#43 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#44 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#45 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#46 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#47 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#48 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#49 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#50 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#51 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#52 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#53 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#54 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#55 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#56 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#57 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#58 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#59 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#60 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#61 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#62 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
#63 0x00007fd050a4e557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27557)
Stack trace of thread 749:
#0 0x00007fd0500d946f __poll (libc.so.6 + 0xf546f)
#1 0x00007fd04ed7493f n/a (libglib-2.0.so.0 + 0xa693f)
#2 0x00007fd04ed1f2b1 g_main_context_iteration (libglib-2.0.so.0 + 0x512b1)
#3 0x00007fd0507de6e1 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e6e1)
#4 0x00007fd0507843fc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43fc)
#5 0x00007fd05078c894 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2bc894)
#6 0x000055657d4d32b4 n/a (baloo_file + 0xd2b4)
#7 0x00007fd05000c152 __libc_start_main (libc.so.6 + 0x28152)
#8 0x000055657d4d34be n/a (baloo_file + 0xd4be)
Stack trace of thread 768:
#5 0x00007fd05059cd22 _ZN7QThread4execEv (libQt5Core.so.5 + 0xccd22)
#6 0x00007fd050a72098 n/a (libQt5DBus.so.5 + 0x17098)
#7 0x00007fd05059df0f n/a (libQt5Core.so.5 + 0xcdf0f)
#8 0x00007fd04f5d43e9 start_thread (libpthread.so.0 + 0x93e9)
#9 0x00007fd0500e4293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 780:
#0 0x00007fd0500dbc96 pselect (libc.so.6 + 0xf7c96)
#1 0x00007fd04e7c7524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
#2 0x00007fd04e7c88a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
#3 0x00007fd04f5d43e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007fd0500e4293 __clone (libc.so.6 + 0x100293)
░░ Subject: Process 749 (baloo_file) dumped core
░░ Defined-By: systemd
░░ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ Documentation: man:core(5)
░░ Process 749 (baloo_file) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
ene 06 12:34:57 siempresolo systemd[1]: Failed to start Samba NMB Daemon.
░░ Subject: A start job for unit nmb.service has failed
░░ A start job for unit nmb.service has finished with a failure.
░░ The job identifier is 81 and the job result is failed.
ene 06 12:34:57 siempresolo smbd[1530]: [2021/01/06 12:34:57.715792, 0] …/…/lib/util/become_daemon.c:135(daemon_ready)
ene 06 12:34:57 siempresolo smbd[1530]: daemon_ready: daemon ‘smbd’ finished starting up and ready to serve connections
ene 06 12:36:13 siempresolo systemd[664]: Failed to start EOS update notifier service.
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 106 and the job result is failed.
lines 86-141/141 (END)
I also installed the libbpf
library and the bpf
package without success.
Here on a fresh VM linux-hardened worked OK.
Hard to tell what the problem is. May be related to some additionally installed programs (from AUR perhaps?).
Mmm… not from AUR I don’t think since I don’t have much installed from Aur:
cnrdrvcups-lb-bin 5.20-1
cups-bjnp 2.0.3-1
ee-editor 1.5.2-4
ifstat 1.1-1
popsicle-git 1.3.0.r1.g1685d80-1
printer-support 1-2
samba-support 1-2
scanner-support 1-2
