After Switching GPUs, Audio Jacks Aren't Working/Being Detected
Hello! I’m pretty new to Linux, but I’ll try to explain with as much detail as I can.
The audio from my Razer BlackShark V2 stopped working after I switched from an RTX 2070 to a RX Radeon 6600. Switching back to the old GPU is not a favorable solution since it is a little defective. The non-working audio seems to be the only issue that has come up due to the switch.
I have had an issue with my audio in the past, due to me incorrectly uninstalling things, but it was solved by completely reinstalling Endeavouros. I’d rather not do that again.
I’ve alredy tried looking in the Volume Control Configuration screen and Alsamixer, but my headphones just dont seem to show up.
Below is some information, any help on this would be appreciated!
System Info
Operating System: EndeavourOS
KDE Plasma Version: 6.2.5
KDE Frameworks Version: 6.10.0
Qt Version: 6.8.2
Kernel Version: 6.13.2-arch1-1 (64-bit)
Graphics Platform: X11
Processors: 16 × AMD Ryzen 7 2700 Eight-Core Processor
Memory: 15.5 GiB of RAM
Graphics Processor: AMD Radeon RX 6600
Manufacturer: Micro-Star International Co., Ltd
Product Name: MS-7C02
System Version: 1.0
Audio Info
Module #1
	Argument: {
            nice.level    = -11
            rt.prio       = 88
            #rt.time.soft = -1
            #rt.time.hard = -1
            #uclamp.min = 0
            #uclamp.max = 1024
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-rt"
		object.id = "1"
		object.serial = "1"
		module.author = "Wim Taymans <wim.taymans@gmail.com>"
		module.description = "Use realtime thread scheduling, falling back to RTKit"
		module.usage = "( nice.level=<priority: default 20(don't change)> ) ( rt.prio=<priority: default 83> ) ( rt.time.soft=<in usec: default -1> ) ( rt.time.hard=<in usec: default -1> ) ( rlimits.enabled=<default true> ) ( rtportal.enabled=<default true> ) ( rtkit.enabled=<default true> ) ( uclamp.min=<default 0> ) ( uclamp.max=<default 1024> )"
		module.version = "1.2.7"
		nice.level = "-11"
		rt.prio = "88"
Module #2
	Argument: {
            # List of server Unix sockets, and optionally permissions
            #sockets = [ { name = "pipewire-0" }, { name = "pipewire-0-manager" } ]
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-protocol-native"
		object.id = "2"
		object.serial = "2"
		module.description = "Native protocol using unix sockets"
Module #4
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-profiler"
		object.id = "4"
		object.serial = "4"
		module.description = "Generate Profiling data"
Module #6
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-metadata"
		object.id = "6"
		object.serial = "6"
		module.description = "Allow clients to create metadata store"
Module #8
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-spa-device-factory"
		object.id = "8"
		object.serial = "8"
		module.description = "Provide a factory to make SPA devices"
Module #10
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-spa-node-factory"
		object.id = "10"
		object.serial = "10"
		module.description = "Provide a factory to make SPA nodes"
Module #12
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-client-node"
		object.id = "12"
		object.serial = "12"
		module.description = "Allow clients to create and control remote nodes"
Module #14
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-client-device"
		object.id = "14"
		object.serial = "14"
		module.description = "Allow clients to create and control remote devices"
Module #16
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-portal"
		object.id = "16"
		object.serial = "16"
Module #17
	Argument: {
            # Socket-specific access permissions
            #access.socket = { pipewire-0 = "default", pipewire-0-manager = "unrestricted" }
            # Deprecated legacy mode (not socket-based),
            # for now enabled by default if access.socket is not specified
            #access.legacy = true
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-access"
		object.id = "17"
		object.serial = "17"
		module.description = "Perform access check"
		module.usage = "( access.socket={ <socket>=<access>, ... } ) ( access.legacy=true ) "
Module #18
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-adapter"
		object.id = "18"
		object.serial = "18"
		module.description = "Manage adapter nodes"
Module #20
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-link-factory"
		object.id = "20"
		object.serial = "20"
		module.description = "Allow clients to create links"
		module.usage = "( allow.link.passive=<bool, default false> ) "
Module #22
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-session-manager"
		object.id = "22"
		object.serial = "22"
		module.author = "George Kiagiadakis <george.kiagiadakis@collabora.com>"
		module.description = "Implements objects for session management"
Module #536870912
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Pauli Virtanen <pav@iki.fi>"
		module.description = "Always keeps at least one sink loaded even if it's a null one"
		module.usage = "sink_name=<name of sink>"
Module #536870913
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Keep track of devices (and their descriptions) both past and present and prioritise by role"
		module.usage = "do_routing=<Automatically route streams based on a priority list (unique per-role)?> on_hotplug=<When new device becomes available, recheck streams?> on_rescue=<When device becomes unavailable, recheck streams?>"
Module #536870914
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore the volume/mute state of devices"
		module.usage = "restore_port=<Save/restore port?> restore_volume=<Save/restore volumes?> restore_muted=<Save/restore muted states?> restore_formats=<Save/restore saved formats?>"
Module #536870915
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore the volume/mute/device state of streams"
		module.usage = "restore_device=<Save/restore sinks/sources?> restore_volume=<Save/restore volumes?> restore_muted=<Save/restore muted states?> on_hotplug=<This argument is obsolete, please remove it from configuration> on_rescue=<This argument is obsolete, please remove it from configuration> fallback_table=<filename>"
Sink #59
	State: SUSPENDED
	Name: alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00.analog-stereo
	Description: Yeti Stereo Microphone Analog Stereo
	Driver: PipeWire
	Sample Specification: s16le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: no
	Volume: front-left: 26214 /  40% / -23.88 dB,   front-right: 26214 /  40% / -23.88 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00.analog-stereo.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "0"
		alsa.card_name = "Yeti Stereo Microphone"
		alsa.class = "generic"
		alsa.components = "USBb58e:9e84"
		alsa.device = "0"
		alsa.driver_name = "snd_usb_audio"
		alsa.id = "USB Audio"
		alsa.long_card_name = "Blue Microphones Yeti Stereo Microphone at usb-0000:03:00.0-3, full speed"
		alsa.mixer_name = "USB Mixer"
		alsa.name = "USB Audio"
		alsa.resolution_bits = "16"
		alsa.subclass = "generic-mix"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.sync.id = "00000000:00000000:00000000:00000000"
		api.alsa.card.longname = "Blue Microphones Yeti Stereo Microphone at usb-0000:03:00.0-3, full speed"
		api.alsa.card.name = "Yeti Stereo Microphone"
		api.alsa.path = "front:0"
		api.alsa.pcm.card = "0"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		card.profile.device = "4"
		device.api = "alsa"
		device.class = "sound"
		device.id = "50"
		device.profile.description = "Analog Stereo"
		device.profile.name = "analog-stereo"
		device.routes = "1"
		factory.name = "api.alsa.pcm.sink"
		media.class = "Audio/Sink"
		device.description = "Yeti Stereo Microphone"
		node.name = "alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00.analog-stereo"
		node.nick = "Yeti Stereo Microphone"
		node.pause-on-idle = "false"
		object.path = "alsa:acp:Microphone:4:playback"
		port.group = "playback"
		priority.driver = "1009"
		priority.session = "1009"
		factory.id = "19"
		clock.quantum-limit = "8192"
		client.id = "48"
		node.driver = "true"
		node.loop.name = "data-loop.0"
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "59"
		object.serial = "59"
		api.acp.auto-port = "false"
		api.acp.auto-profile = "false"
		api.alsa.card = "0"
		api.alsa.split-enable = "true"
		api.alsa.use-acp = "true"
		api.dbus.ReserveDevice1 = "Audio0"
		api.dbus.ReserveDevice1.Priority = "-20"
		device.bus = "usb"
		device.bus-id = "usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00"
		device.bus_path = "pci-0000:03:00.0-usb-0:3:1.0"
		device.enum.api = "udev"
		device.form_factor = "microphone"
		device.icon_name = "audio-input-microphone-analog-usb"
		device.name = "alsa_card.usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00"
		device.nick = "Yeti Stereo Microphone"
		device.plugged.usec = "6358199"
		device.product.id = "0x9e84"
		device.product.name = "Yeti Stereo Microphone"
		device.serial = "Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-3/1-3:1.0/sound/card0"
		device.vendor.id = "0xb58e"
		device.vendor.name = "Blue Microphones"
		spa.object.id = "2"
		device.string = "0"
	Ports:
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability unknown)
	Active Port: analog-output-speaker
	Formats:
		pcm
Sink #61
	State: SUSPENDED
	Description: Navi 21/23 HDMI/DP Audio Controller Digital Stereo (HDMI 5)
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Mute: no
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_28_00.1.hdmi-stereo-extra4.monitor
	Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
	Properties:
		alsa.card = "1"
		alsa.card_name = "HDA ATI HDMI"
		alsa.components = "HDA:1002aa01,00aa0100,00100800"
		alsa.device = "10"
		alsa.driver_name = "snd_hda_intel"
		alsa.id = "HDMI 4"
		alsa.long_card_name = "HDA ATI HDMI at 0xfcb20000 irq 64"
		alsa.mixer_name = "ATI R6xx HDMI"
		alsa.name = "VG278"
		api.alsa.card.longname = "HDA ATI HDMI at 0xfcb20000 irq 64"
		api.alsa.card.name = "HDA ATI HDMI"
		api.alsa.path = "hdmi:1,4"
		api.alsa.pcm.card = "1"
		card.profile.device = "17"
		device.api = "alsa"
		device.id = "51"
		device.profile.description = "Digital Stereo (HDMI 5)"
		device.profile.name = "hdmi-stereo-extra4"
		device.routes = "1"
		device.description = "Navi 21/23 HDMI/DP Audio Controller"
		node.name = "alsa_output.pci-0000_28_00.1.hdmi-stereo-extra4"
		node.nick = "VG278"
		object.path = "alsa:acp:HDMI:17:playback"
		priority.driver = "584"
		priority.session = "584"
		factory.id = "19"
		client.id = "48"
		object.id = "36"
		object.serial = "61"
		api.alsa.card = "1"
		api.dbus.ReserveDevice1 = "Audio1"
		device.bus = "pci"
		device.bus_path = "pci-0000:28:00.1"
		device.icon_name = "audio-card-analog-pci"
		device.name = "alsa_card.pci-0000_28_00.1"
		device.nick = "HDA ATI HDMI"
		device.plugged.usec = "6129074"
		device.product.id = "0xab28"
		device.product.name = "Navi 21/23 HDMI/DP Audio Controller"
		sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:26:00.0/0000:27:00.0/0000:28:00.1/sound/card1"
		device.vendor.id = "0x1002"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
		spa.object.id = "4"
		device.string = "1"
	Ports:
		hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, availability group: Legacy 5, available)
	Active Port: hdmi-output-4
	Formats:
		pcm
Sink #62
	State: SUSPENDED
	Description: Family 17h (Models 00h-0fh) HD Audio Controller Pro
	Driver: PipeWire
	Sample Specification: s32le 8ch 48000Hz
	Channel Map: aux0,aux1,aux2,aux3,aux4,aux5,aux6,aux7
	Mute: no
	Volume: aux0: 65536 / 100% / 0.00 dB,   aux1: 65536 / 100% / 0.00 dB,   aux2: 65536 / 100% / 0.00 dB,   aux3: 65536 / 100% / 0.00 dB,   aux4: 65536 / 100% / 0.00 dB,   aux5: 65536 / 100% / 0.00 dB,   aux6: 65536 / 100% / 0.00 dB,   aux7: 65536 / 100% / 0.00 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_2a_00.3.pro-output-0.monitor
	Properties:
		alsa.card = "2"
		alsa.card_name = "HD-Audio Generic"
		alsa.components = "HDA:10ec0892,1462ec02,00100302"
		alsa.device = "0"
		alsa.id = "ALC892 Analog"
		alsa.long_card_name = "HD-Audio Generic at 0xfcf00000 irq 65"
		alsa.mixer_name = "Realtek ALC892"
		alsa.name = "ALC892 Analog"
		alsa.resolution_bits = "32"
		api.alsa.card.longname = "HD-Audio Generic at 0xfcf00000 irq 65"
		api.alsa.card.name = "HD-Audio Generic"
		api.alsa.path = "hw:2,0"
		api.alsa.pcm.card = "2"
		audio.channels = "8"
		audio.position = "AUX0,AUX1,AUX2,AUX3,AUX4,AUX5,AUX6,AUX7"
		card.profile.device = "1"
		clock.name = "api.alsa.2"
		device.api = "alsa"
		device.id = "52"
		device.profile.description = "Pro"
		device.profile.name = "pro-output-0"
		device.profile.pro = "true"
		device.routes = "0"
		device.description = "Family 17h (Models 00h-0fh) HD Audio Controller"
		node.name = "alsa_output.pci-0000_2a_00.3.pro-output-0"
		node.nick = "ALC892 Analog"
		object.path = "alsa:acp:Generic:1:playback"
		priority.driver = "1500"
		priority.session = "1500"
		factory.id = "19"
		client.id = "48"
		object.id = "47"
		object.serial = "62"
		api.alsa.card = "2"
		api.dbus.ReserveDevice1 = "Audio2"
		device.bus = "pci"
		device.bus_path = "pci-0000:2a:00.3"
		device.name = "alsa_card.pci-0000_2a_00.3"
		device.nick = "HD-Audio Generic"
		device.plugged.usec = "6160293"
		device.product.id = "0x1457"
		device.product.name = "Family 17h (Models 00h-0fh) HD Audio Controller"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/sound/card2"
		device.vendor.id = "0x1022"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
		spa.object.id = "6"
		device.string = "2"
	Formats:
		pcm
Source #59
	State: SUSPENDED
	Name: alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00.analog-stereo.monitor
	Description: Monitor of Yeti Stereo Microphone Analog Stereo
	Driver: PipeWire
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	Monitor of Sink: alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00.analog-stereo
	Properties:
		alsa.card = "0"
		alsa.device = "0"
		device.api = "alsa"
		device.class = "monitor"
		device.id = "50"
		device.routes = "1"
		factory.id = "19"
		client.id = "48"
		object.id = "59"
		api.alsa.card = "0"
		device.bus = "usb"
		spa.object.id = "2"
		device.string = "0"
	Ports:
	Formats:
		pcm
Source #60
	State: SUSPENDED
	Name: alsa_input.usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00.analog-stereo
	Driver: PipeWire
	Mute: no
	Volume: front-left: 52685 /  80% / -5.69 dB,   front-right: 52685 /  80% / -5.69 dB
	        balance 0.00
	Base Volume: 38295 /  58% / -14.00 dB
	Monitor of Sink: n/a
	Properties:
		alsa.card = "0"
		alsa.device = "0"
		api.alsa.pcm.stream = "capture"
		card.profile.device = "0"
		device.api = "alsa"
		device.id = "50"
		device.routes = "1"
		factory.name = "api.alsa.pcm.source"
		media.class = "Audio/Source"
		node.name = "alsa_input.usb-Blue_Microphones_Yeti_Stereo_Microphone_797_2017_11_19_33506-00.analog-stereo"
		object.path = "alsa:acp:Microphone:0:capture"
		port.group = "capture"
		priority.driver = "2009"
		priority.session = "2009"
		factory.id = "19"
		client.id = "48"
		object.id = "60"
		object.serial = "60"
		api.alsa.card = "0"
		device.bus = "usb"
		spa.object.id = "2"
		device.string = "0"
	Ports:
		analog-input-mic: Microphone (type: Mic, priority: 8700, availability unknown)
	Active Port: analog-input-mic
	Formats:
		pcm
Source #61
	State: SUSPENDED
	Description: Monitor of Navi 21/23 HDMI/DP Audio Controller Digital Stereo (HDMI 5)
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Monitor of Sink: alsa_output.pci-0000_28_00.1.hdmi-stereo-extra4
	Properties:
		alsa.card = "1"
		alsa.device = "10"
		alsa.id = "HDMI 4"
		alsa.name = "VG278"
		device.api = "alsa"
		device.id = "51"
		device.routes = "1"
		node.nick = "VG278"
		factory.id = "19"
		client.id = "48"
		object.id = "36"
		api.alsa.card = "1"
		device.bus = "pci"
		spa.object.id = "4"
		device.string = "1"
	Ports:
	Formats:
		pcm
Source #62
	State: SUSPENDED
	Description: Monitor of Family 17h (Models 00h-0fh) HD Audio Controller Pro
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Monitor of Sink: alsa_output.pci-0000_2a_00.3.pro-output-0
	Properties:
		alsa.card = "2"
		alsa.device = "0"
		device.api = "alsa"
		device.id = "52"
		device.routes = "0"
		factory.id = "19"
		client.id = "48"
		object.id = "47"
		api.alsa.card = "2"
		device.bus = "pci"
		spa.object.id = "6"
		device.string = "2"
	Formats:
		pcm
Source #63
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		alsa.card = "2"
		alsa.device = "0"
		audio.position = "AUX0,AUX1"
		card.profile.device = "2"
		device.api = "alsa"
		device.id = "52"
		device.profile.name = "pro-input-0"
		device.routes = "0"
		node.name = "alsa_input.pci-0000_2a_00.3.pro-input-0"
		object.path = "alsa:acp:Generic:2:capture"
		priority.driver = "2500"
		priority.session = "2500"
		factory.id = "19"
		client.id = "48"
		object.id = "45"
		object.serial = "63"
		api.alsa.card = "2"
		device.bus = "pci"
		spa.object.id = "6"
		device.string = "2"
	Formats:
		pcm
Source #64
	State: SUSPENDED
	Description: Family 17h (Models 00h-0fh) HD Audio Controller Pro 2
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		alsa.card = "2"
		alsa.device = "2"
		alsa.id = "ALC892 Alt Analog"
		alsa.name = "ALC892 Alt Analog"
		api.alsa.path = "hw:2,2"
		card.profile.device = "3"
		device.api = "alsa"
		device.id = "52"
		device.profile.description = "Pro 2"
		device.profile.name = "pro-input-2"
		device.routes = "0"
		node.name = "alsa_input.pci-0000_2a_00.3.pro-input-2"
		node.nick = "ALC892 Alt Analog"
		object.path = "alsa:acp:Generic:3:capture"
		priority.driver = "2212"
		priority.session = "2212"
		factory.id = "19"
		client.id = "48"
		object.id = "46"
		object.serial = "64"
		api.alsa.card = "2"
		device.bus = "pci"
		spa.object.id = "6"
		device.string = "2"
	Formats:
		pcm
Sink Input #100
	Driver: PipeWire
	Owner Module: n/a
	Client: 99
	Sink: 62
	Sample Specification: float32le 2ch 48000Hz
	Format: pcm, format.sample_format = "\"float32le\""  format.rate = "48000"  format.channels = "2"  format.channel_map = "\"front-left,front-right\""
	Corked: yes
	Mute: no
	        balance 0.00
	Buffer Latency: 0 usec
	Sink Latency: 0 usec
	Resample method: PipeWire
	Properties:
		client.api = "pipewire-pulse"
		pulse.server.type = "unix"
		application.name = "Firefox"
		application.process.id = "1488"
		application.process.user = "landonh"
		application.process.host = "landon-ms7c02"
		application.process.binary = "firefox"
		application.language = "en_US.UTF-8"
		window.x11.display = ":0"
		application.process.machine_id = "da7a4f43065c4380bd2dac096ff1b1bd"
		application.process.session_id = "2"
		media.name = "SituationShip 64 - YouTube"
		node.rate = "1/48000"
		node.latency = "3600/48000"
		stream.is-live = "true"
		node.name = "Firefox"
		node.want-driver = "true"
		node.autoconnect = "true"
		media.class = "Stream/Output/Audio"
		port.group = "stream.0"
		adapt.follower.spa-node = ""
		object.register = "false"
		factory.id = "7"
		client.id = "94"
		object.id = "95"
		object.serial = "100"
		pulse.attr.maxlength = "4194304"
		pulse.attr.tlength = "48000"
		pulse.attr.prebuf = "38408"
		pulse.attr.minreq = "9600"
		module-stream-restore.id = "sink-input-by-application-name:Firefox"
Client #32
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.protocol = "protocol-native"
		core.name = "pipewire-landonh-1291"
		pipewire.sec.socket = "pipewire-0-manager"
		pipewire.sec.pid = "1291"
		pipewire.sec.uid = "1000"
		pipewire.sec.gid = "1000"
		module.id = "2"
		object.id = "32"
		object.serial = "32"
		application.version = "0.5.8"
		wireplumber.daemon = "true"
		wireplumber.profile = "main"
		application.name = "WirePlumber"
		remote.name = "[pipewire-0-manager,pipewire-0]"
		config.name = "null"
		context.modules.allow-empty = "true"
		application.process.binary = "wireplumber"
		application.process.id = "1291"
		cpu.max-align = "32"
		default.clock.rate = "48000"
		default.clock.quantum = "1024"
		default.clock.min-quantum = "32"
		default.clock.max-quantum = "2048"
		default.clock.quantum-limit = "8192"
		default.clock.quantum-floor = "4"
		default.video.width = "640"
		default.video.height = "480"
		default.video.rate.num = "25"
		default.video.rate.denom = "1"
		log.level = "2"
		clock.power-of-two-quantum = "true"
		link.max-buffers = "64"
		mem.warn-mlock = "false"
		mem.allow-mlock = "true"
		settings.check-quantum = "false"
		settings.check-rate = "false"
		core.version = "1.2.7"
		pipewire.access = "unrestricted"
		session.services = "[api.alsa-seq, api.alsa, midi, api.libcamera, bluetooth.audio, audio, api.bluez, policy.default-nodes, video-capture, policy.linking.standard, bluetooth.midi, policy.linking.role-based, api.v4l2, policy.device.profile, policy.device.routes]"
Client #33
	Driver: PipeWire
	Owner Module: 2
	Properties:
		core.name = "pipewire-landonh-991"
		pipewire.sec.socket = "pipewire-0"
		pipewire.sec.pid = "991"
		module.id = "2"
		object.id = "33"
		object.serial = "33"
		pipewire.access.portal.is_portal = "true"
		portal.monitor = "Camera"
		application.name = "xdg-desktop-portal"
		application.process.binary = "xdg-desktop-portal"
		application.process.id = "991"
		log.level = "0"
Client #34
	Driver: PipeWire
	Owner Module: 2
	Properties:
		core.name = "pipewire-landonh-1294"
		pipewire.sec.pid = "1294"
		module.id = "2"
		object.id = "34"
		object.serial = "34"
		config.name = "pipewire-pulse.conf"
		application.name = "pipewire"
		application.process.binary = "pipewire"
		application.process.id = "1294"
		log.level = "2"
Client #35
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "35"
		object.serial = "35"
		application.name = "libcanberra"
		application.version = "0.30"
		application.id = "org.freedesktop.libcanberra"
		application.process.id = "1061"
		application.process.binary = "kded6"
		log.level = "2"
Client #48
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "48"
		object.serial = "48"
		application.name = "WirePlumber [export]"
		wireplumber.export-core = "true"
		log.level = "2"
Client #49
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "49"
		object.serial = "49"
		application.name = ""
		application.id = "org.kde.kded6"
		application.icon_name = ""
		log.level = "2"
Client #95
	Driver: PipeWire
	Owner Module: 2
	Properties:
		core.name = "pipewire-landonh-1113"
		pipewire.sec.pid = "1113"
		module.id = "2"
		object.id = "90"
		object.serial = "95"
		application.name = "plasmashell"
		application.process.binary = "plasmashell"
		application.process.id = "1113"
		log.level = "0"
Client #96
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "91"
		object.serial = "96"
		log.level = "2"
Client #97
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "92"
		object.serial = "97"
		application.id = "org.kde.plasma-pa"
		log.level = "2"
Client #98
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "93"
		object.serial = "98"
		window.x11.screen = "0"
		log.level = "2"
Client #99
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "94"
		object.serial = "99"
		log.level = "2"
Client #155
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "150"
		object.serial = "155"
		application.version = "135.0"
		application.icon_name = "firefox"
		log.level = "2"
Client #206
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "100"
		object.serial = "206"
		application.process.id = "3968"
		application.process.binary = "pactl"
		application.name = "pactl"
		log.level = "2"
Sample #0
	        balance 0.00
	Duration: 0.3s
	Lazy: no
	Filename: n/a
	Properties:
		event.id = "audio-volume-change"
		event.description = "Volume Control Feedback Sound"
		media.role = "event"
		media.name = "audio-volume-change"
		media.filename = "/usr/share/sounds/ocean/stereo/audio-volume-change.oga"
Card #50
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.alsa.card = "0"
		api.alsa.path = "hw:0"
		device.api = "alsa"
		device.bus = "usb"
		media.class = "Audio/Device"
		spa.object.id = "2"
		factory.id = "15"
		client.id = "48"
		object.id = "50"
		object.serial = "50"
		object.path = "alsa:acp:Microphone"
		alsa.card = "0"
		alsa.id = "Microphone"
		device.string = "0"
	Profiles:
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
		output:analog-stereo+input:iec958-stereo: Analog Stereo Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 6555, available: yes)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
		output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
		output:iec958-stereo+input:iec958-stereo: Digital Stereo Duplex (IEC958) (sinks: 1, sources: 1, priority: 5555, available: yes)
		output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
		output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: yes)
		output:iec958-ac3-surround-51+input:iec958-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 355, available: yes)
		output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
		input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
		pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
	Active Profile: output:analog-stereo+input:analog-stereo
	Ports:
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "mic"
				device.icon_name = "audio-input-microphone"
				card.profile.port = "0"
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
		iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "spdif"
				card.profile.port = "1"
			Part of profile(s): input:iec958-stereo, output:analog-stereo+input:iec958-stereo, output:iec958-stereo+input:iec958-stereo, output:iec958-ac3-surround-51+input:iec958-stereo
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "speaker"
				device.icon_name = "audio-speakers"
				card.profile.port = "2"
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:iec958-stereo
		iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "spdif"
				card.profile.port = "3"
			Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-stereo+input:iec958-stereo
Card #51
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.alsa.card = "1"
		api.alsa.path = "hw:1"
		device.api = "alsa"
		device.bus = "pci"
		spa.object.id = "4"
		factory.id = "15"
		client.id = "48"
		object.id = "51"
		object.serial = "51"
		object.path = "alsa:acp:HDMI"
		alsa.card = "1"
		alsa.id = "HDMI"
		device.string = "1"
	Profiles:
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: yes)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		pro-audio: Pro Audio (sinks: 5, sources: 0, priority: 1, available: yes)
	Active Profile: output:hdmi-stereo-extra4
	Ports:
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 1"
				device.icon_name = "video-display"
			Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 2"
			Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
		hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 3"
			Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
		hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 4"
			Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
		hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, availability group: Legacy 5, available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 5"
				card.profile.port = "4"
				device.product.name = "VG278"
			Part of profile(s): output:hdmi-stereo-extra4
Card #52
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.alsa.card = "2"
		api.alsa.path = "hw:2"
		device.api = "alsa"
		device.bus = "pci"
		spa.object.id = "6"
		factory.id = "15"
		client.id = "48"
		object.id = "52"
		object.serial = "52"
		object.path = "alsa:acp:Generic"
		alsa.card = "2"
		alsa.id = "Generic"
		device.string = "2"
	Profiles:
		output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
		output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
		output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
		output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
		output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
		output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
		output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
		output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
		output:analog-surround-71+input:analog-stereo: Analog Surround 7.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
		output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
		output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
		output:analog-surround-71: Analog Surround 7.1 Output (sinks: 1, sources: 0, priority: 1200, available: no)
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
		pro-audio: Pro Audio (sinks: 1, sources: 2, priority: 1, available: yes)
	Active Profile: pro-audio
	Ports:
		analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
			Properties:
				port.type = "mic"
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:analog-surround-71+input:analog-stereo
		analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
			Properties:
				port.type = "mic"
		analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 3, not available)
			Properties:
				port.type = "line"
		analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, not available)
			Properties:
				port.type = "line"
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-71, output:analog-surround-71+input:analog-stereo
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, available)
			Properties:
				port.type = "headphones"
				device.icon_name = "audio-headphones"
Ah, forgot to mention I also updated the native packages, but that also didn’t work.
I just looked at alsamixer again and it was just muted lol
