Have you booted into the other installation and checked if it is using the same module?
sudo nano /etc/modprobe.d
unless you use vimâŚ
Exactly so switch to the r8169 module.
Edit:
sudo modprobe -r r8168
sudo modprobe r8169
Edit: See if it works after. Actually i should have said to remove the r8168 first.
It was probably because there was an update to the r8168 module. Or itâs because you reinstalled and the r8169 doesnât work for most so i think the r8168 was added to the ISO packages. and you would have had to do exactly what you are doing if it didnât work on your hardware. Itâs just one of those issues that one has to deal with; with hardware.
Edit: Some users hardware doesnât work with the r8169 and some donât work with the r8168
Iâm not sure because the fact is that hardware can use either or? as far as i know? I think you could remove the r8168 if you wanted.
Edit: But it may be a dependency of the printer packages or something else so maybe not? ButâŚiâm thinking you can.
No that just removes the module but it is in the packages. I looked in pamac and i have it on mine.
[ricklinux@eos-xfce ~]$ inxi -n
Network: Device-1: Broadcom and subsidiaries BCM4360 802.11ac Wireless Network Adapter
driver: wl
IF: wlan0 state: dormant mac: xx:xx:xx:xx:xx:xx
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: xx:xx:xx:xx:xx:xx
I am using the r8168 and i have the Broadcom chip for wifi
Edit:
You may not be able to remove it! But you could black list it.
No i know itâs just something that can be done. Not suggesting you need to. I wouldnât worry too much as you know whatâs going on now.
Edit: As long as itâs working for you now you should be good.
Your time and answers are gratefully appreciated. Thanks
SOLVED (see msg #1)
Didnât you try the solution described here then? https://forum.manjaro.org/t/solved-r8168-ethernet-cannot-connect-after-resume-from-sleep/92212/26
Thanks for posting the solution, I was going crazy trying to figure out why the network was âconnectedâ but not working at all⌠uninstalling the r8169 package and rebooting fixed the problem.
It is gratifying that the problem has finally been resolved.
