Advice music player with my favourite options?
I want to use music player in linux, what hide in tray when I close the window and looks good.
Before posting I used Strawberry, because I like it design, and other options, it has infinite bufferization, and net does not help to resolve this problem.
I dislike design of Amarok and Elisa, because they have not only list of songs, but other column, which I cannot hide.
Audacious cannot hide tray.
Which player should I choose?
I like Fooyin. The UI is completely customizable and you can close to try if you want that.
Here is what mine looks like but all of these are widgets you can add or remove(there are others beyond the ones I am using).
EDIT: I guess I just disclosed my semi-diverse music tastes.
Running fooyin for local music. Running strawberry for Radio Streams
icon looks bad(
Hey,
I selfhost my own music, so ive been down this rabbit hole once before hhaha
I use feishin now, it is by far the best music player i have used until now, go give it a try - it is open source as well. I use Symfonium on my phone. I can confirm:
  • It does minimise to tray (i don’t personally use this myself, but i tested just now)
  • Favicon for it looks great
  • It has support for connection with navidrome
When right-clicking the Feishin tray icon:
Other previews:
That looks pretty interesting. I may test it out. Thanks for sharing.
It simply changes to any one at will.
  • как настроить эту программу?
И в трее меняется элементарно. По крайней мере в KDE Plasma.
And the tray icon changes elementary. At least in KDE Plasma.
How?
Не торопись. Через час всё тебе расскажу на родном и великом языке.
Do not rush. In an hour, I’ll tell you everything in my native and great language.
Concur! These two are by far the best music players I’ve found for my laptop and phone that link to my Navidrome server.
I just noticed that feishin-bin is removed from the AUR now, replaced with feishin in the ‘extra’ repo.
