Adding/changing mirrors while traveling abroad
I live in the US but am traveling in the Middle East for work and brought my laptop with eos on it. I just realized I need to install a piece of software. I ran checkupdates as a test and it eventually went through but was very slow. Should I run reflector-simple and add mirrors for the country I’m in, or could that have negative consequences?
No, that is fine.
Just run it again when you return to the US.
I would backup my current file, THEN reflector-simple or maybe rate-mirrors for new choices. Returning to your usual afterwards is trivial…
Edit: I type too slowly!
If it is me I would launch “welcome” app and update mirrors.
I would repeat after I return back.
Thanks all.
