I have this setup: i3-6006u, 16GiB RAM, Nvidia 920m (NVE0 family (Kepler)), intel hd graphics 520, ssd. And i run the latest linux-zen kernel from repos
The problem is that i want to run TF2 on linux using nvidia card, but trying to install drivers results in blurry game (like it’s being rendered at 640x480 and is upscaled afterwards) and around 10 fps on an empty map
nvidia’s site says that my card supports 430 driver from 2019 and latest 390 driver from 2021
arch wiki says: For the Kepler (NVE0) series (including GeForce 630-920) from around 2013-2014, install the nvidia-470xx-dkms(AUR) package.
What I’ve tried so far:
Optimus-manager with nvidia-390xx-dkms, nvidia-470xx-dkms, nvidia-dkms (latest 495 driver). Tried to compile nvidia-430xx-dkms but COMPILATION TERMINATED.
Endeavouros script nvidia-installer-dkms (link) which tells me to use it with --force and then install nvidia-390xx-dkms but it creates a dependency problem and pacman just stops the process. Tried it with -b for bumblebee but it installs 495 drivers which don’t work at all and if i install bumblebee manually with 390 it seems to run OpenGL test with optirun but TF2 won’t even start
nouveau with DRI_PRIME=1, runs a bit better but 20 fps and slowmo menu is no go
Haven’t only tried nvidia-xrun yet
im sorry if this is a duplicate or something like this, i’m just really lost at this point
Your graphics card (id: 1299) is supported by the nvidia-390xx-dkms driver.
To install a driver for this card:
Use the --force option with nvidia-installer-dkms.
Then, BEFORE rebooting, install nvidia-390xx-dkms from the AUR.
For example:
yay -S nvidia-390xx-dkms
and if i do this it results in:
→ nvidia-390xx-utils-390.147-1 already made – skipping build
loading packages…
resolving dependencies…
looking for conflicting packages…
:: nvidia-390xx-utils and nvidia-utils are in conflict (nvidia-libgl). Remove nvidia-utils? [y/N] y
:: removing nvidia-utils breaks dependency ‘nvidia-utils=495.46’ required by nvidia-dkms
→ exit status 1
You can as well use the 470 series of Nvidia drivers.
But as the error messages say, there are conflicting packages.
That’s why you need to uninstall all conflicting Nvidia packages and install related 470 packages.
So uninstall at least
nvidia-dkms
nvidia-utils
and install
nvidia-470xx-dkms
nvidia-470xx-utils
Unfortunately the output of some commands is not fully up to date, but we are working on it.
