Following up on what I mentioned in this thread, now that the system is installed, I would like to analyze and understand how the system was installed before continuing.
About the disk configuration
I did a straightforward installation, since I wanted something simple with Calamares, but I’m surprised by how the disks turned out, and I’m not sure if I did something wrong.
Disk partitions and volumes
$ lsblk -o name,type,size,PTTYPE,FSTYPE,MOUNTPOINT
NAME TYPE SIZE PTTYPE FSTYPE MOUNTPOINT
sda disk 4,5T gpt
└─sda1 part 4,5T gpt exfat /run/media/asim/Wd-Elements
nvme0n1 disk 476,9G gpt
├─nvme0n1p1 part 2G gpt vfat /efi
└─nvme0n1p2 part 474,9G gpt crypto_LUKS
└─luks-8ae62143-bd48-4652-beae-61d9e211417f crypt 474,9G btrfs /var/log
$ sudo btrfs subvolume list /var/log
ID 256 gen 149 top level 5 path @
ID 257 gen 150 top level 5 path @home
ID 258 gen 113 top level 5 path @cache
ID 259 gen 150 top level 5 path @log
ID 260 gen 29 top level 5 path @swap
ID 261 gen 24 top level 256 path @/var/lib/portables
ID 262 gen 24 top level 256 path @/var/lib/machines
The questions that arise for me are:
- Is mounting in /var/log logical? The truth is that I expected it to be in /, and maybe I’m talking nonsense.
- I’m missing a volume for snapshots.
- Do I need to correct something? Where can I read about how to do what needs to be done?
About home.
I think the idea of protecting data is important; it wouldn’t be the first time I’ve gotten into trouble over it. ![]()
Until now, my system, which is probably less efficient, has been based on organizing my /home directory in a similar way to what Karl Voit suggests in this post.
From there, I modify the .config/user-dirs.dirs file and update with xdg-user-dirs-update.
This works quite well, although there are always programs that don’t use user-dirs.locale properly and create some or don’t conform to the standard and recreate some folders that force me to redirect.
The weak point is that sometimes, for fear of losing things, I duplicate copies, and this is very inefficient in terms of space. To copy a script with rsync from those folders, I manage. Any suggestions for improving my backup system are welcome. About my disk and /home.
Best regards.
