The latest vivaldi-snapshot 3.4.2035.3-1 is “out of sync” update vise with vivaldi-snapshot-ffmpeg-codecs 85.0.4183.84-1 and/or vivaldi-widevine 1:4.10.1679.0-1.
This is usually only temporary, and will get fixed in a day or to, but if you’re planing on watching Netflix tonight, you might want to hold that update.
Are you per chance on regular Vivaldi, as I tried those instructions before, and they do not work for snapshot?
I’m fully aware that it’s an reoccurring problem, but I found it to be a kind thing to give a heads up for those running vivaldi-snapshot with vivaldi-snapshot-ffmpeg-codecs and widevine.
Friends and family doesn’t seem to take kindly to “no Netflix today”…
I understand your position on this issue. Some people just want to use the browser and don’t care what needs to be done to do so. Otherwise, to fix the error, obviously you need the code below, unlike the code described in the link. sudo /opt/vivaldi-snapshot/update-ffmpeg
PS. By the way, how do you spell the select and copy link at the end of a code text? I used the preformatted text button to enter the code into the post.
