Installer won’t launch without nomodeset, and after installing it boots and just gives no display signal at all, but my card works.
A last gen and GPU should be supported in the newest arch kernels right?? What is happening here??
It also won’t work with kubuntu, and fedora locks at low resolution and refuses to use sound devices.
I got endeavourOS to work, switched to kubuntu which nuked itself and became unbootable after the first boot.
Now absolutely nothing has changed, and all these problems appear with endeavourOS, I can’t figure out why.
How did you get it to work. What is the motherboard?
inxi -M
I used the same live USB to install it, except the second time I used it I couldn’t boot without nomodeset, and after installing it in the same way, now I have no video signal. I just used the live installer both times.
MSI pro b650p wifi mobo with newest not beta bios, 7600x cpu, 1tb SSD, and 32 GB of ddr5 ram.
To clarify, I installed endeavourOS, it worked, installed kubuntu instead over all of it, and it broke itself, so I formated over kubuntu’s bricked installation with endeavourOS the same way I installed before, but now I have no video.
Solved, memory error.
My PC was broken, so I replaced the PSU after getting an upgrade on ram and rma’ing the whole PC except the PSU from a crappy brand which I replaced.
Reseat my freshly and seemingly correctly installed ram.
Boots instantly but can’t use old windows install.
Okay.
Decide to just wipe it for Linux instead of repairing, works, then stops working randomly.
Eventually it turned into boot looping.
Hey, screw it, sure, reseat the ram again I guess.
Bam, instant boot into endeavourOS with no issues.
Dude, idk, like I just don’t know how the ram was loose again, but uhhh, yeah I’m good.
