Funny you should mention that, i actually did & had the same issue.
You could add EnOS repo to your Arch install
There have been a couple of threads on the forum as well about how to convert Arch to Endeavour and vice versa.
I believe this is the thread youâre referring to? Adding link for future reference
Yes, that would be one. If my memory serves me right, there have been a couple of others as well. I didnât search for them though
It wonât add pipewire correct?
By adding EnOS* repo you will be able to install EnOSâ tools on your system.
So if you go ahead and install pipewire again I am not sure you will have the same issue as described above or not. Honestly I couldnât tell.
@Christopher67
Maybe this helps https://archlinux.org/packages/?name=pipewire-docs
@Christopher67
There is also a pipewire-alsa package so i donât know where that fits in? It seems to me that everything is sort of intertwined so to speak. This is my current audio output on anew install of kde.
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 2d:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-arch2-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: yes
In the alsa settings you can actually specify the 5.1 audio according to the Arch wiki. I donât know some apps may choose independently audio output also?
