Hi guys
I just installed eos in a x86_64 pc (xfce).
Everything works perfectly (no problems)
I wanted to know just for information:
If I want to install a program should I also install the 32 bit version?
For example if I want to install vulkan-Intel in addition to the standard 64bit version I have to add the 32bit version?
Or I can safely use the 64-bit version and that’s it?,
dalto
2
In the case of a library, you need the 32-bit library if you run any 32-bit applications that use that library.
I don’t know if you need that specific 32-bit library but I can tell you that many games are 32-bit.
(Remember to mark dalto’s post above as the solution if it answered your question)
system
Closed
5
