2in1 Laptop issues with Pen and display
Hey, so I recently got back into using my 2in1 Laptop more again due to going to school again. The model is a 2021 Asus Flow X16 with 32gb memory, a 6800hs and a 3060. I reinstalled Endeavour as i wanted to try out Gnome as I had some issues with Plasma before.
The issue is that whenever I use my Pen in the 2in1 mode it jumps to one corner or to the right side of the screen and only goes back to the right location after clicking the pen pointer on the touchscreen. I couldnt get this to happen while in “normal” Laptop mode. My second issue is, that the screen is flickering red/green when doing anything.
I sadly couldnt find any info on this specific issue especially on the pen. Maybe someone has more info
To add to this: its on a fresh install and I updated nvidia drivers via nvidia-inst, though via supergfxctl i only use the internal gpu for power saving
The Flow 16 model from 2023 seems to be fully supported. At least according to the Arch Wiki.
Are you aware of rog-control-center within the AUR as well as The Arch guide for ASUS laptops ?
Yes i have that installed as well. Actually i dont have rn but i had before and had the same issue though the display worked fine artifact wise
As I tends to be my most favorite advice recently… have you tried to deactivate the iGPU via BIOS ? I’m not sure if it’s feasible for that mobile CPU. But might be worth a shot.
Id like to use the igpu also i checked once but i couldnt find a setting for this :confused: i think its required as it acts as passthrough even for the dgpu
